Displays the configured meters.
meter_name | Specifies the meter name. |
ports | Ports to display. |
port_group | Port group name. |
port_list | Port list separated by a comma. |
out-actions | Out-of-profile actions. |
N/A.
None.
The following sample output displays meters on the switch:
#show meter ------------------------------------------- Name Committed Rate(Kbps) Peak Rate(Kbps) ------------------------------------------- peggy 1000000--
The following example uses the port-group variable:
# show meter ports ingMeterGrpA Group: ingMeterGrpA Ports: 1-3 Name Committed Rate Peak Rate Burst Size (Kb) -------------------- ----------------- ---------------- --------------- ingmeter2 21000 Kbps 30000 Kbps 2 ingmeter3 30000 Pps 40000 Pps 5 ingmeter4 21000 Kbps -- 2 ingmeter5 30000 Pps -- 5
The following example uses port_group out-actions:
# show meter ingmeter2 ports ingMeterGrpB out-actions Group: ingMeterGrpB Ports: 4-5 Out-actions Drop Meter Log Trap Disable Drop Precedence Name Port (dscp) -------------------------------- --- ---- ------- ---- ---------- ingmeter2 -- On On On 63
The following example uses port_list:
# show meter ports 1-4 Name Committed Rate Peak Rate Burst Size(Kb) Port ------------------- ------------------- ------------------- -------------- ---- ingmeter2 21000 Kbps 30000 Kbps 2 1 ingmeter5 30000 Kbps -- 5 1 ingmeter2 21000 Kbps -- 2 2 ingmeter5 30000 Kbps -- 5 2 ingmeter2 21000 Kbps -- 2 3 ingmeter5 30000 Kbps -- 5 3 ingmeter5 2000 Pps 10000 Pps 3 4 ingmeter7 10000 Kbps -- 5 4
The following example uses port_list out_actions:
# show meter “ingmeter2” ports 4-6 out-actions Out-actions Drop Meter Log Trap Disable Drop Precedence Name Port (dscp) Port -------------------------------- --- ---- ------- ---- ---------- ---- ingmeter2 On On On -- 63 4 ingmeter2 On On On -- 63 5 ingmeter2 On On On On -- 6
You configure a peak rate for QoS meters using the configure meter metername {committed-rate cir [Gbps | Mbps | Kbps | Pps]} {max-burst-size burst-size [Kb | Mb | packets]} {out-actions [{disable-port} {drop | set-drop-precedence {dscp [none | dscp-value]} {dot1p [ none | dot1p-value ]}} {log} {trap}]} {ports [port_group | port_list]} command.
This command was first available in ExtremeXOS 11.4.
The ports,port_group, port_list, and out-actions options were added in ExtremeXOS 16.1.
